2 piece throw out bearing vs 1 piece
So I recently ordered a Hd clutch kit from marlin and when I got it I noticed the throw out bearing was different from the old one. So my question is if I buy the collar piece that marlin sells for the 2 piece setup will it work correctly? Also can I use the old metal clip that holds it to the clutch fork(the metal clip off of the one piece bearing)?
Thanks in advance!
Thanks in advance!
While I'm far from an expert on this I have read recently when shopping for my new clutch kit that the one piece was for the turbo models (maybe others) and is no longer produced. They say to switch over to the two piece (collar and bearing) and it will work fine. You will need two clips as well. Hope this helps.
This is what's in it now. https://www.marlincrawler.com/clutch...g-1990-95-4cyl
Looks like a one piece to me. If that bearing presses on to he hub. But it looks like a one piece.
I don't recall where I saw the mention of the one piece being obsolete but now I'm anxious to know for sure. Try posting on MC's forum. Those guys are always good for info.
09-04-2015 09:27 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
