1st time toyota owner..need help!!
i just recently bought a 95 4runner with warped heads for $700, which i didnt think was a bad at all ...so i went out and bought a long block for it from houston and did an engine swap ..well that wasnt so hard but now the problem is i cant figure out where the vacume hoses connect on the left side of the intake (passenger side) along with the hoses from the power steering pump.....cause the guy who had it b4 me already had took the top half of the engine apart ..so if ne one could help me out with sum pics it would help alot... its a 3vz v6 4x4 95 4runner
thanx
thanx
Welcome to YT, here is a link to some online Toyota Factory service Manuals:
http://www.ncttora.com/fsm/index.html
there are 5 or 6 different manuals, you should be able to find the Vacuum diagrams you need. Post up some pictures of your project sometime...
YT has a very good atmosphere (better than some forums) but a lot of questions may be been answered before, be sure to try the search function...if you don't find what you are looking for to avoid getting flamed be sure to post in the Newbie Tech Folder: https://www.yotatech.com/forums/f120/
Good luck!
Good luck!
i just got done wit all the 8 mile of hose that thing has all i need now is the radiator ,fan ,a couple of pullys and the air box and its componets ... but the only problem i have now is sum of the bolts to a few of the brackets are missing ,so ill probly go to the fastners shop and pick up wut i need.......But two questions i do have are..1. does n e one happen to no the size and dimesions on the bolts for the rear drive shaft that bolt it down to the differential cause the vehicle didnt come with them when i got it ( ps, the 4runer is 4 wheel drive if it makes n e differance)??? ...and 2. Wut would the break in method on the 3.0 b??? n e info would help..thanx
Gotcha on this one zlathim.........
Surch da 4m 4 da brak in procjures uzng doze keewurds.
Pul 1 bolt frum da frunt DS 2 match 1 ^ at da parts stor.
6th Gear
19
12-10-2019 07:31 AM
voiddweller
19
05-02-2016 09:10 PM
saphirekosmos
06-22-2015 10:26 AM
