1st LIFT!!!! Need opinion & advice
I’ve research and now ready to make a move, I need some confirmation guys. I’m planning on lifting my runner to fit 33’s to 35’s for some moderate outdoors activity. No hard CORE wheeling like some of you folks, but still what that OFF IM A O.G. YOTA look. This will be my first lift ever…I have a 88 Runner 4x4 3.0 V6 AUTO IFS, my issue is:
1. With a Tuff Country 4-5 inch lift and 2-inch Body lift will I clear & no rubbing on 35x12.50 R15 tires w/ Pro Comp 15x8 6on5.5 wheel with 4.5 backspacing??
2. The Tuff Country 4-5 inch lift that are mostly offer, is it a complete bolt on setup with NO modifications?
3. Why is it so hard to find Body Lifts for automatic? Almost no body sells them. Can anyone recommend?
4. As for gears, I think I have the 4.56, can I use the gear for now OR should I really upgrade to the 5.29 gears? Anyone recommend a brand with reasonable cost? “Again not going to be DD as well. Only my weekend outdoor ride with little DD..”
Any suggestion would really fill in the blanks in my head….=)
#3- body lifts for automatics are hard to find because of two things:
---- floor shifters slide front to back and lifting the shifter means that the linkage under the shifter doesn't move as far so they don't make them. yeah, they could convert the linkage to a cable setup but they won't.
---- column shifters have the linkage go through the firewall next to the steering column and no one wants to make a simple extended link in order to make the lift kit work.
4Crawler makes an auto body lift... The key is in the extended shifter brackets...
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
4.56's won't be horrible with 33, but you should re-gear for either. 5.29's for 33's and 5.71's for 35's..
Just a reminder 33x10.5/15's will fit with no lift....
Hope this helps
Larry
Hope this helps
Larry
Hope this helps
Larry
Hope this helps
Larry
Im pretty darn sure most of the Bracket lifts out there require cutting out the main crossmember in the front end to drop everything down.
In anycase, go with full leaves in the pack, no blocks. You will regret them.
And 5.71's with 35's is as good as its gonna get for you.
kirkrunner
07-27-2015 07:59 PM
britishdudes2dr
07-25-2015 06:47 AM
MTLroadierunner
07-20-2015 03:07 PM
Vargntucson
07-04-2015 12:15 PM
