1st Generation Rear Window Relay Refurbishing
Okay i have a question for those who have/may have or will soon be refurbishing their rear window relay on the 1st Gen 4Runners.
I have done a bit of looking around and see the following relays being used to fix their relays. Which did you use or which would you use.
G5LE-1-DC12
This relay part seems to be to big to fit in the enclosure, but many are using it.
SRD-S-112D
This relay seems to fit better into the enclosure and it seems to work well.
please tell me which you think is better.
G5LE-1-DC12
SRD-S-112D
Staff
I havent looked into the relays you are showing but thought I would add some info from 4Crawlers write up. >>>> http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Good One Terry, glad to see you here as well...
Here's another link to a 1st Gen rear window relay repair:
https://www.yotatech.com/forums/f115...tralia-219010/
And using pretty much the similar tech here's the second gen 4runner rear window repair:
https://www.yotatech.com/forums/f128/back-window-relay-fix-1990-4runner-137310/
The relays they use i think are the same relays, so there shouldn't be an issue to use either relay, at least that is what I think. Its just a matter of preference.
06-01-2021 01:51 PM
the1998sr5
15
07-14-2020 08:35 PM
icentropy
07-14-2015 10:23 AM
Johntom240
7
07-13-2015 12:18 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
