1st gen 89 cluster lights no worky
i have changed the bulbs in the cluster and still no worky...
i did originally have two burnt green coated bulbs, so i went and changed them. this usually fixes the issue but in this case no matter what i can not get them to work. the blue circuit board/paper thing is intact and all the other lights are working. blinkers, brights ( only when on the flash setting. if i put them on full time brights the light goes out.) etc. the only two lights that are not working are the cluster lights.
any help?
thank you in advance,
murphy
any help?
murphy
i did check that, i took out the connector thingy and cleaned it and the contacts, that made it work. so now i am cruising with lights in my cluster yahoo!!
06-01-2021 01:51 PM
Esibnitsud
07-30-2015 08:21 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
