1st gen 4runner Auto Trans
Old 04-02-2009, 05:47 PM
rocklover's Avatar
Hey Ive got another question before i move forward buying the 87. It has an automatic transmission. I had the 5 speed manual in my 85 truck. I was just wondering how well the automatic transmission holds up and how well it performs?
Old 04-02-2009, 06:40 PM
Dan.3's Avatar
Its a tough auto. 340f. same auto behind the supercharged 3.4. so if you would ever want to upgrade the trans should bolt up to the 3.4. The wiring harness connection might be a little different so it wont be a direct plug in but you could still make it work.
Old 04-03-2009, 11:39 AM
OutlawMike's Avatar
What engine is in that '87? V6 or 4 Cylinder?
The V6's came with the A340H, which is in the same family as the A340F.
Most 4 cylinders came with the A340F.
The big difference is the fact that the A340H has an integrated transfer case. It is essentially another trans bolted on the back and it contributes to the lack of power in the V6 autos. Lots of drag.
The A340F has a separate, bolt on chain drive transfer case.
If you want to do a doubler down the line, it is very expensive to do it on the A340H.
Link for you, all you really want to know:
http://www.pirate4x4.com/forum/showt...roubleshooting
Mike
Old 04-03-2009, 06:53 PM
Dan.3's Avatar
they didnt make the v6 in 87 so it would be a 4 cylinder
06-01-2021 01:51 PM
andrewtexas123
07-14-2015 04:29 AM
coryc85
07-06-2015 04:07 AM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 1st gen 4runner Auto Trans
