1995 Toyota T100 Speed sensor /Shifting problem
Old 04-05-2016, 10:46 AM
DStarry's Avatar
I have a 1995 Toyota T100 4X4, 3.4 liter V6 automatic.
OD light had been flashing intermittently when up to speed. No longer flashing, however it is having issues shifting from first to second when you first start up the vehicle and try to go. You can rev up the RPMs to about 4K and then it will shift and go no problem. I am thinking this is a speed sensor issue. Is this correct? If so is it located on the rear left side of the tranny?
