1995 4Runner wire harness
Old 03-07-2015, 06:04 AM
kpnalder1's Avatar
I've looked through many threads and still can't quite find what I'm looking for. I have a '95 4Runner and as you know, the stock headlights aren't much brighter than a candle. Obviously I want more light and know that replacing the stock wiring harness with an upgraded harness and maybe some different bulbs can give me more light. I think I would rather buy a harness than make one as I don't have a lot of spare time. My question is where can I find a harness that is plug and play? I've looked and many of the links I've found in older threads are no longer good and I believe 4crawler no longer makes them. Does anyone know where I could buy one from or have a great how to on making one? Any help would be greatly appreciated. Thanks! Also, what would be a good bulb to switch to with just a wire harness upgrade?
Old 03-07-2015, 06:45 AM
Shady Cadence's Avatar
Check your ground first
To the left of the drivers feet, behind the plastic kick panel there is a grounding point. If you have cruise control, it's under the upper mount for the cruise ecu. Remove the ecu and look closely where the connector is crimped on the wire. If there's black or green discoloration, cut it off and crimp a new one on, reconnecteverything and try your headlights.
Old 03-07-2015, 07:24 AM
millball's Avatar
Here is the type I put on my '95 Runner:
http://www.ebay.com/itm/HD-Head-Lamp-Headlight-Wiring-Harness-For-High-Wattage-Bulbs-9004-100-90w-Kit-/381167063743?vxp=mtr
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Regency
20
01-03-2020 07:43 PM
MMA_Alex
25
04-18-2017 05:07 AM
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 1995 4Runner wire harness
