1995 4Runner performance Mods? - YotaTech Forums
Go Back   >
Old 02-09-2016, 09:43 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Specifications & General Maintenance
Print Wikipost
LinkBack Thread Tools Search this Thread
Old 08-06-2008, 03:39 PM   #1
Ok right now i got the K&N intake kit i got the Flowmaster super 40 exhaust, and a Jet performance chip(Big Difference) what other bolt ons can i get to help turn my 32 Toyo Mud Terrains.
4Runner831 is offline   Reply With Quote
Old 08-06-2008, 03:41 PM   #2
tc
tc's Avatar
a 3.4 swap
Are you actually claiming that the Jet chip made a big difference, or everything together made a difference?
tc is offline   Reply With Quote
Old 08-06-2008, 03:42 PM   #3
RobD's Avatar
Take the 3.0 out. Push it over a cliff. That's the fastest that motor will ever go.
Find 3.4 from newer Tacoma/4Runner and drop it in. Spending money on a 3.0 is like polishing a turd.
RobD is offline   Reply With Quote
Old 08-06-2008, 03:42 PM   #4
RobD's Avatar
Quote:
Originally Posted by tc View Post
a 3.4 swap
Damn, you beat me to it.
Old 08-06-2008, 04:04 PM   #5
abecedarian's Avatar
and other bolt ons... hmm....
... regear?
abecedarian is offline   Reply With Quote
Old 08-06-2008, 05:30 PM   #6
Matt16's Avatar
Regear. It makes a tonne of difference even going from 4.10 to 4.56. Second (off road performance) buy a locker- I'd hate it if I'd invested in MTs and some truck with ATs was able to go farther.
Matt16 is offline   Reply With Quote
Old 08-06-2008, 05:42 PM   #7
>snip<
... the Jet chip made a big difference...
>snip<
the only thing the jet chip does is alter the coolant temp sensor signal to cause a slightly richer fuel mixture. it doesn't affect timing, or anything else for that matter. and it doesn't even do it intelligently. it's just a resistor biasing the coolant sensor towards colder engine temps.
Old 08-06-2008, 07:50 PM   #8
Jay351's Avatar
Yep, those chips are junk. Im sure you're getting less then average fuel mileage now.
As for mods:
Intake (you seem to have it covered with the overrated K&N fipk)
Cams (expensive, hard to install, worth the gains if you can)
Headers (again expensive, hard to install but they are worth a few hp)
Other then that, you need to get into oversized valves and so forth, it gets pricey quick.
I wouldnt bother doing anything that expensive unless you are rebuilding the engine and want to get it running better.
Save for a 5vfze or even the 1uz swap. Much more power available from those engines.
Re-gear your differentials to 4.88 if you have a 5sp or 5.71 if you have an auto. This will help low end power
Jay351 is offline   Reply With Quote
Old 08-06-2008, 08:38 PM   #9
tc
tc's Avatar
Quote:
That was kinda my point ... with as locked down as ALL Toyota ECU's are, chips can't make much of a difference.
Old 08-08-2008, 10:39 PM   #10
ok so the k&n kit i vey overrated and too expensive but ca is bitch bout smog. and the jet chip helped my acc. dramatically.
Old 08-09-2008, 12:09 AM   #11
Matt16's Avatar
Buy a Supra?
Old 08-09-2008, 05:06 AM   #12
STEVE_R's Avatar
mmmm, i say sell the aftermarket crap you have on there now to some other sucker, part out rest of motor on e-bay, and drop in a 3.4. i'm just waiting for the day my motor goes bye-bye! ok, so i help it along at times! checkout asap motors, the 3.4 is actually $200 cheaper than the 3.o (3.4-$1500 3.0-$1700).
STEVE_R is offline   Reply With Quote
RedRunner_87's aka "Operation Mall Crawler" Build Thread RedRunner_87 95.5-2004 Tacomas & 96-2002 4Runners (Build-Up Section) 60 01-14-2017 05:16 PM
88 Pickup Transmission Swap mskalmus 86-95 Trucks & 4Runners 6 03-21-2016 12:41 PM
rear bump stops for zuk mod, don't have them! icentropy 86-95 Trucks & 4Runners 10 07-11-2015 08:21 AM
94' Pickup ZUK Mod - What Springs? Nickdigg 86-95 Trucks & 4Runners 1 07-07-2015 07:04 AM
Tags
1993, 1995, 4runner, 95, calgary, chip, dan, grant, iasca, improve, jet, mods, performance, pontiac, review, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
