1994 3.0 4x4 ext cab dead miss at idle only
Old 06-19-2010, 05:42 PM
unklslam41's Avatar
all cylinders are firing, but at idle i have a dead miss. my number 6 cylinder was not firing untill i did some upper cylinder cleaner and freed what i imagined a sticky valve or lots of carbon causing it not to close. the truck runs awesome when driving just not at idle. i have done a complete tune up, and checked everything i know to check. the truck had a head gasket installed and sat for two years. i purchased it from a guy i work with i bugged him daily till he finally sold me the truck. other than the miss the miss its flawless. 150k miles and not a spec of rust. any ideas on what the problem could be. im willing to try anything to get the truck back to normal state.
Old 06-21-2010, 03:55 PM
Flash319's Avatar
Take the ignitor box off the fender and sand under it so that it has a good ground. This worked for a guy I know but I have not seen it work. The ignitor grounds through the case and must have a good ground on the fender (so I have been told).
God's Bounty Hunter
07-08-2015 12:54 PM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
Steezy96yota
07-06-2015 10:00 AM
elwood73
07-05-2015 07:07 AM
Quick Reply: 1994 3.0 4x4 ext cab dead miss at idle only
