1993 toyota pickup temperature guage sensor location?
Old 12-07-2015, 09:48 PM
dishplayer's Avatar
I have a 93 with a v6 project and it has been having some issues witn running rough and someone suggested changing out the temp sensor so I did along with the temp cold start sensor however I also need to change my guage sensor as my temp guage stopped working and this seams like the logical next step since ive already changed out the thermostat. The problem I cant find the darn thing. The sensor im looking for is 83420-16020. I thought it was next to the other two but I dont see it?
Old 12-07-2015, 10:24 PM
scope103's Avatar
A picture would help. The block that holds the various temperature sensors varies a lot between models (for instance: a 4wd WITH Automatic has an extra temperature sensor, so the block is different).
Old 12-08-2015, 07:20 AM
dishplayer's Avatar
Back of engine next to firewall. This truck is a 4x4 manual transmission with the v6.
The one on the right is the temp sensor that I replaced and I thought the one on the left was the Guage sensor but it does not appear to have a threaded nut on it
Side view with air intake removed.
Old 12-09-2015, 11:58 PM
wyoming9's Avatar
Red face
looking at the EWD for the 94 it shows it at the back of the engine with a grey plug
Yellow/ green stripe wire
It grounds via the sensor.
I hope this helps yours may be different but it should be in the same place.
81 4X4
12-05-2015 07:26 PM
SubiKing
11-25-2015 12:50 PM
moparbay
11-22-2015 09:03 PM
80seriesftw
11-22-2015 07:50 PM
Jonny246
11-12-2015 03:28 PM
Quick Reply: 1993 toyota pickup temperature guage sensor location?
