1993 Toyota pickup 3.0
Old 09-15-2016, 08:29 PM
90orbetter's Avatar
I have a 1993 Toyota pickup has new cat new muffler new cap rotor plugs wires mas air flow sensor truck has 65k miles on it so truck went and smog and it threw egr valve code so changed egr valve check engine light went off then can back on after 20 miles I need to smog truck but can't figure it out please help !!!!!
Old 09-16-2016, 04:34 AM
cbr600rx7's Avatar
Did you test or replace the EGR temp sensor?
Clean out the EGR filter?
Check all vacuum lines running to the EGR?
Old 09-16-2016, 04:43 AM
90orbetter's Avatar
[QUOTE=cbr600rx7;52335131]Did you test or replace the EGR temp sensor?
Check all vacuum lines running to the EGR?[/QUOTE
where is the egr filter and the temp sensor ?
Old 09-16-2016, 04:47 AM
cbr600rx7's Avatar
Search and you will know.
Try "3VZE EGR temp sensor" and "3vze EGR filter" I bet you find what information you seek.
Remember Google and the search function are your friends and you can download the FSMs for free.
Old 09-17-2016, 02:04 AM
Toyauts's Avatar
Message deleted by Terrys87
Last edited by Terrys87; 09-17-2016 at 07:21 AM. Reason: Post padding with no useful answers
Old 09-17-2016, 03:35 AM
cbr600rx7's Avatar
Not really. The EGR system on the 3.0 is very simple. Most of the time the failure is the temp sensor or a simple vacuum issue.
nbl300
07-27-2018 09:34 AM
85shortYota
11-30-2017 12:20 PM
surf4life
09-19-2016 09:29 AM
pursang
07-09-2016 01:48 AM
Maple
06-28-2016 07:31 PM
Quick Reply: 1993 Toyota pickup 3.0
