1993 toyota 4 Runner
Old 07-07-2006, 04:31 PM
onebadazztoy's Avatar
here's my problem, does anyone know how to get a stripped lugnut off alloy wheels without using a cutting torch. i have tried other tools that suppose to remove stripped out lugnuts but so far have not worked for me if have any suggestion please let me know.
Old 07-07-2006, 06:18 PM
Steveh29's Avatar
Is it on the rear wheel with the aluminum rims? If so, you can pop of the center cap and have plenty of room to take a grinder or dremel tool to the lug nut and slice it lengthwise and then chisel it off. Also works on the front wheel if you have room to get it in there around the hub plate.
Old 07-07-2006, 08:18 PM
^VooDoo^'s Avatar
Steve's Idea is great for the rear, For the front use a drillbit larger then the threds of the bolt, drill it till it reaches the rotor and it will fall off, Replace lugbolt.
If you take the rotor off first, and drill from back and punch rest of lug out of the front you can save time and slap the new lug right in before you mount the rotor
Old 07-08-2006, 08:48 AM
thanks for everyone advice. and it was the right front side where im trying to replace my pg headed starter. thanks for everyone who responded
Old 07-08-2006, 01:13 PM
MMA_Alex's Avatar
i had to have my mechanic torch the locking type off my explorer once, it actually turned out pretty well, and didnt damage the wheel at all, just had a little soot to wash off.
Old 07-09-2006, 09:57 AM
mikes350's Avatar
did one of these last night ,got my bj spacers so thought i'd put them in , last owner had locking wheel nuts and i haven't replaced them yet and of course i lost the key for them , try'd most of the other tricks as well , i ended up grinding sides on it and hammering a impact socket onto it then using the impact gun to undo it , worked for all four ,
Old 07-09-2006, 10:23 AM
mt_goat's Avatar
The dealer has replacement keys for the Toyota factory locking lug nuts ($20)
Old 07-09-2006, 01:44 PM
MMA_Alex's Avatar
so do most of the cheapo locking lug manufacturers, as long as you know the key number. On the one i had to have cut off though the stud actually stripped out of the back of the rotor, and was spinning freely in the rotor. either way my point was that if you torch it right it wont damage alloy wheels
Old 07-09-2006, 03:08 PM
mt_goat's Avatar
Yeah that's good to know. I always use anti-seize on my lug studs
Weidle
01-21-2019 05:39 AM
Colington
10-12-2015 05:41 PM
Gamble_STi
06-27-2015 07:54 PM
nyk08trx
06-18-2015 09:01 PM
NerfHerder-97SR5-
06-17-2002 05:31 PM
Quick Reply: 1993 toyota 4 Runner
