1993 t100 interchangeable rear end
I suppose he didn't specify which year though, taking a second reading (if so, he posted in the wrong section). Tacoma, Tundra, Sequoia, and T100 diffs are all the same size and will fit in a T100 housing.
Sorry, forgot to read the thread again.
Yes, you can just swap the entire assembly, as long as you verify ratio first. If the donor truck matches your trucks ratio, then its a super easy swap. Just unbolt the axle from the leaf springs and unhook the brakes, then swap-a-roo!
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
07-09-2015 02:18 PM
