1993 22RE poor fuel mileage
Old 11-19-2011, 01:14 PM
brownstone63's Avatar
I have a 93 toyota truck with a 22re and 4x4. At it's best im getting 270 miles out of a tank.....that's just under 20mpg. The engine seems to run pretty smooth but at the exhaust there's a little hiccup. Also I just noticed the manifold is glowing hot! Help please!!!
Old 11-19-2011, 03:05 PM
gb42's Avatar
I'd love to get 20mpg
Old 11-19-2011, 04:17 PM
Sensei's Avatar
If your exhaust manifold is glowing red hot that usually means a plugged catalytic converter. That will decrease mpg. 18-20 mpg is pretty standard for 22re/4x4.
tacotacoma96's Avatar
For starters what size tires are you running? A bigger tire makes the motor work harder so it causes less gas mileage. Some things you can do to get more power and some better gas mileage is a Cold Air Intake that will show you a big improvent and give you a few extra miles. a good set of spark plugs. Id say E3s. they help burn the gas better and make the engine run better. I hope this helped you.
Old 11-19-2011, 06:02 PM
BoredOutnJackdUp's Avatar
It really just depends. 20 is GREAT!
i have a header cold air intake and 33s. and got 15-16 on the free way.
And tires dont have THAT big of a difference.
Charecter1
11-06-2023 10:08 AM
Colington
03-08-2020 09:51 AM
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
kcaudill
07-20-2015 12:06 PM
Quick Reply: 1993 22RE poor fuel mileage
