1993 22re engine pinging
Old 04-07-2008, 01:58 PM
fowlman's Avatar
well, i finally found base timing on my 93 hilux 4x4. after setting the idle at 850, and experimenting with the timing starting at base (e1/te1 jumped) 5 BTDC, it had significant pinging. then backed up to about 2 BTDC and still have a noticable ping, even after using a good quality gas (BP or EXXON). i checked the vac lines and they appear to be correct and also the rotor, cap and wires look good, btw they are only a year old.any ideas where to go next to stop this pinging condition?
Old 04-08-2008, 01:56 PM
Keith B.'s Avatar
Sounds like mine...if I put 87 octane(which it is supposed to accomodate) in it it pings like crazy. With 91 octane it pings variably at highway speeds. Dealer techs (including the supervisor, for what it's worth) said leave it, it's fine. Everything is stock, timing set correctly, and when installed, the rebuilt engine did it EXACTLY the same as the old, original 22RE. I'd love a solution, but "nothing's wrong" with the car!
Charecter1
11-06-2023 10:08 AM
Colington
03-08-2020 09:51 AM
steve miller
10-10-2015 01:40 AM
crashburnoveride
08-28-2015 09:20 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: 1993 22re engine pinging
