1992 Toyota Pickup Tick Noise
Curious if anyone can help diagnose the ticking noise in my Yota. Check out my youtube video I uploaded. The smog pump is kinda loud. Also, does it sound like my timing chain is slapping the cover when I give it gas?
Thanks,
Hunter
Pulled the valve cover, drivers side chain guide is gone, chain has barely touched the chain cover though. Guess she will have to sit until I can get the timing chain replaced.
engnbldr.com call them talk to Ted.
order:
you want
waterpump
oil pump
timing set with steel rail on driver side
upper gasket set
you said timing cover was good?
Should be like $100 some odd bucks? Been several months since I did mine.
Toyota head gasket. Manditory.
order:
you want
waterpump
oil pump
upper gasket set
6th Gear
19
12-10-2019 07:31 AM
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
