1992 pickup speedometer electric or cable driven?
Old 03-07-2011, 08:01 AM
matt92yota's Avatar
i picked up an sr5 gauge cluster from the junkyard this past weekend and it is cable driven, but i was wondering if my 1992 pickup was either electric or cable before i start taking my dash apart.
Old 03-07-2011, 08:14 AM
Birdbrain's Avatar
I am fairly confident that its an electronic... I think 92-94 was the years for the electronic speedo sensor.
Old 03-07-2011, 08:18 AM
tj884Rdlx's Avatar
if it's a 22RE manual trans, it should be a cable. you should be able to see it coming through the firewall.
rockauto.com shows it for $8.52
http://www.rockauto.com/catalog/moreinfo.php?pk=15259
Old 03-07-2011, 08:19 AM
xxxtreme22r's Avatar
or stick your head under the truck and look for it on the trans.
Old 03-07-2011, 08:20 AM
Birdbrain's Avatar
You know... Thats not a bad idea actually...
Old 03-07-2011, 08:21 AM
Birdbrain's Avatar
To the OP if its mechanical, it will have a round plug on the back, passenger side of the tranny.
if its electric it will have a black, rectangular plug that you can undo like any other plug on a wiring harness.
Old 03-07-2011, 08:22 AM
matt92yota's Avatar
i'll have to go look once i get out of class lol thanks guys
Old 03-07-2011, 08:23 AM
blake.nemitz's Avatar
mine has an electric speedo sensor and a motor that drives the speedo CABLE under the dash, its a 95
Old 03-07-2011, 08:36 AM
WHAHAHAJR's Avatar
My 92 22re manual is electric...
Old 10-08-2011, 02:58 PM
JeredSmith's Avatar
Speedo cable issues
I have a 1988 4runner that was an automatic with a Speedo cable, but recently swapped it with a 5spd from a 1994. The 94 is set up for an electronic speed sensor. Is there any year when they were interchangeable? Can I still set up a Speedo cable instead of the electronic sensor?
Old 10-08-2011, 05:45 PM
TylerH's Avatar
Great questions. I searched and got the same answer, i guess ill have to check when im flushing the tranny this weekend.
Old 10-08-2011, 11:37 PM
john4wd's Avatar
The 1992 2wd 22R-E 5-speed truck had an electric speedo, It was wreaked and I bought the full gauge cluster for 20 bucks and stuck it in my 93 4wd truck after adjusting the odometer. How to on that is on my build thread...
coryc85
09-09-2015 06:24 AM
Yota.Jay
07-23-2015 08:08 PM
jon.r
07-11-2015 03:34 PM
skoti89
07-06-2015 07:45 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: 1992 pickup speedometer electric or cable driven?
