1992 4 runner electrical issue 3.0 v6
Old 01-03-2014, 04:24 PM
sduck27's Avatar
I had new tires and a idler arm replaced. The truck ran fine the shop called today it won't start. You can push start and it will run. No inside light including dash, no rear light, no heater fan, windshield wipers or clock. The door lights are on, and headlight work. After driving for 10 minutes all turned on. Turned off the car same symptoms as before won't start. Have power from the battery and cold start relay is working but no ignition. Any idea's
Steve
Old 01-03-2014, 05:07 PM
RJR
RJR's Avatar
Check your battery cable connections. Probably a corroded connection at the battery, either hot or ground.
Old 01-03-2014, 05:13 PM
sduck27's Avatar
We changed them
Old 01-03-2014, 06:56 PM
scope103's Avatar
Check the alt and AM1 fuses in the fuse block under the hood. (Headlights are powered before these fuses.) Use a voltmeter; just looking at these fuses can be time consuming and non-productive.
Fuses don't correct themselves after driving, so I'd also use a voltmeter on the ign fuse; this might help you find an intermittent connection inside the fuse block.
Old 01-03-2014, 10:43 PM
RAD4Runner's Avatar
Yep, as Scope says ^^
However, I'm confused...
Originally Posted by sduck27
...it won't start. You can push start ...will run
Meaning it will not crank but has ignition, so it runs.
Turned off the car same symptoms as before won't start... Have power from the battery and cold start relay is working but no ignition
Meaning this time it cranks but no ignition, meaning no combustion, yet it runs?
Old 01-05-2014, 01:06 AM
wyoming9's Avatar
Red face
I gotta wonder if your mechanic was clueless about the Toyota Ignition switch and left it on the whole time it was at their shop .
This used to happen all the time at the local shop I used for inspections young trainees who would leave after a few months when a raise was not offered.
Draining the battery to the point it will not crank but lucky the computer did not go into hibernation mode to protect it`s self.
Driving brought system voltage up enough to power every thing while running .
trickle charge for 24 hours see what happens.
Measuring battery voltage I would say it would be under 12 VDC
Old 01-05-2014, 03:55 AM
sduck27's Avatar
I took to a mechanic friend we think its the ignition switch we have power to the starter, to all the relays. He's going to check it today to see if it has power.
Old 01-07-2014, 03:36 PM
sduck27's Avatar
Mechanic couldn't figure it took it to electrical place, he thinks it the ecu what a reasonable price to replace it.
Old 01-07-2014, 05:26 PM
RAD4Runner's Avatar
Did you do as Wyoming suggested^^^? Did you answer our questions?
... it won't start. You can push start and it will run.... No inside light including dash, no rear light, no heater fan, windshield wipers or clock.
Originally Posted by scope103
Check the alt and AM1 fuses in the fuse block under the hood....
Your mechanic has no clue. You can take out the ECU and would still have "inside light including dash, no rear light, no heater fan, windshield wipers AND clock".
Old 01-07-2014, 11:32 PM
wyoming9's Avatar
Red face
I gotta wonder how a no crank issue leads to a bad ECU
I gotta wonder how a mechanic can`t figure it out.
I can only guess the new tires no longer provide enough power to the vehicles electrical system in some alien physics way unknown to the rest of us.
New Tires and a idler arm tied into the electrical system in some unknown way .
Very Interesting !!!
Old 01-08-2014, 04:33 PM
sduck27's Avatar
So after much to do I had a short in the engine compartment fuse box. Everything is now working.
Old 01-09-2014, 09:02 AM
scope103's Avatar
... so I'd also use a voltmeter on the ign fuse; this might help you find an intermittent connection inside the fuse block.
So after much to do I had a short in the engine compartment fuse box. ....
helps to read the answers to your posts ....
Old 01-09-2014, 10:15 AM
sduck27's Avatar
I did read them, but the Truck was in the mechanics garage not mine. he was working on it. In the future the truck will stay in my garage.
JF9243176
10-08-2017 04:21 AM
noahstancik
07-10-2015 11:18 AM
irish_tyrant
07-06-2015 11:22 AM
Alex Bessinger
06-28-2015 10:05 AM
JF9243176
06-24-2015 04:53 AM
Quick Reply: 1992 4 runner electrical issue 3.0 v6
