1992 3.0 hc (ppm) way too high
You're idling way too rich. Run the check procedure (from the diagnostic connector) of the O2 sensor. If it works at speed but not at idle, you could have a problem in the heater circuit (though that should throw a code). You could have an exhaust leak (air mixed in exhaust makes it look lean to O2 sensor, ECM incorrectly moves rich).
The other readings would be helpful. http://www.autoshop101.com/ / Technical Articles / Emission analysis
nframe
3.4 Swaps
08-16-2015 09:03 AM
ZONAYODA
07-13-2015 07:17 PM
