1992 22re Pick up Started to lose power lost all poer now will not start any Ideas?
Old 01-15-2011, 07:52 AM
BUSINESS808's Avatar
Hello, I have a 1992 pickup 2wd 22re. I was driving the other day and the car began to lose power I drove a mile or two toward home and it died. It still cranks over. For awhile I thought it was the cat being plugged. So I went had lunch and tried it cooled off. It acted a little more interested in running. You could crank the starter and it would fire for a very short time. I got some tools went back to the truck to split the exhaust at the front of the cat. On return to the vehicle She wouldn't start. So I towed it home. I checked fuses and they are all good. My next step is the igniter/coil and distributor. Got any Ideas?
Old 01-15-2011, 07:56 AM
xxxtreme22r's Avatar
might wanna check out this thread and see if applies to you as well.
https://www.yotatech.com/forums/f116...ak-too-227404/
it helps to let us know what you have tried so far so we aren't spinning our wheels for no reason.
And before you start replacing stuff, it's a good thing to test things first.
Old 01-15-2011, 08:46 AM
Thanks for the lead. I will let you know what I find. I had recently replaced the Transmission. I will check to make sure the sensor connections are good. I have a flat bed and the fuel tank was covered with snow and ice for about a week. I will check the fuel pump wires. When cranking after splitting the exhaust I did smell gasoline. That is why I was leaning toward spark check first.
rbravo1
06-29-2015 01:34 PM
sharrack
06-26-2015 09:33 AM
slider417
06-22-2015 10:18 AM
Quick Reply: 1992 22re Pick up Started to lose power lost all poer now will not start any Ideas?
