1992 22re oli pump not priming
ok so ive put assembly lube in the pump, took out the spark plugs, sat there and cranked her for idk 10-20 minitues and nothing so...... is there a way to prime these things a different way and get to finally prime?? or did i F something up.. and yes it has oil in it..
on top of the oil pump...there is a brass plug...remove said plug..and pour some oil into the hole...this is called manually priming your oil pump. put said plug back into the hole...then see what happens. lol
well after using a hand held oil pump (tubelike w/a plunger and hose on end) pumped oil thgough the oil filter hole cranked it for idk a minute then the pressure gauge sprang up to 20+ so thanks but i got it!..
jon.r
07-11-2015 03:34 PM
