1992 22re no oil presser after 250 mile rebild mark oli change
Old 01-29-2011, 09:31 PM
MILLER91's Avatar
changed the oil at the 250mile break in mark and now its got no oil presser. the gauge dosent even register. so i took off oil filter bone dry, the tried starting it w/oil filter off to see if it would squirt out, and nothing. it had good oil presser before the oil change. pleze help
Old 01-30-2011, 01:05 AM
myyota's Avatar
When you rebuilt the engine did you buy a new oil pump or use the old one ?. I would pull the oil pump and check it out, if its the old pump it could be bad. I had the oil pump on my 86 4Runner grenade it self and i never would have known it happened if it wasn`t for the metal chunks causing the crank shaft seal to leak. When i removed the oil pump it was full of metal chunks, i had to replace the oil pump and the drive gear.
Old 01-30-2011, 01:11 AM
wyoming9's Avatar
Red face
Did you remember to put oil in?/ If the oil is up to the full mark.
Leave the drain plug out??
Big puddle under truck?
The only thing it could be is your oil pump has died the final death.
Or maybe the pick up fell off just finger tighten the bolts.:jessica:
Old 01-30-2011, 08:23 PM
MILLER91's Avatar
it has a new oil pump, no the trucks full, now that it sat over night it started right up with oil pressure... so i don't understand what was going on...
Old 01-30-2011, 09:28 PM
Blue 89 Runner's Avatar
Whose oil filter did you put on ?
Old 01-30-2011, 10:00 PM
sam333's Avatar
If one system needs to be bullit proof on an engine its lubrication( and it usually is ). That is not normal and you should find out whats going on before you start driving again or you may ruin your new engine. I would at least pull you pan and make sure your pick up isnt blocked or loose also I would cut open your old filter if you still have it( also your current one if oil has been through it).
Old 01-30-2011, 11:33 PM
wyoming9's Avatar
Red face
When you had no oil pressure did you check the dip stick there may be a problem with the oil draining down into the pan.
In which case it will starve for oil in running all the oil up top and none in the pan.
As said something to figure out something is not as it should be!!!
Old 01-31-2011, 06:24 AM
fierohink's Avatar
It could be some crap in the oil pressure sending unit that blocked it from seeing pressure. Iw ould swap over to a new sender and aftermarket gauge. Or run a T out of the fitting and keep the factory gauge but still add an aftermarket gauge for comparson and double redundancy.
Old 01-31-2011, 02:21 PM
MILLER91's Avatar
i have a wet gauge there is no sending units, and i put Lucas oil stabliser for rebuilt engines and it now has oil pressure to spare.
Old 01-31-2011, 05:25 PM
What does it have for pressure ?
Old 01-31-2011, 10:59 PM
MILLER91's Avatar
it has 60psi at cold start about 40+at warm start and 10 to 12 at idle
bigjstang
08-25-2021 12:41 AM
God's Bounty Hunter
07-08-2015 12:54 PM
Vargntucson
07-04-2015 12:15 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 1992 22re no oil presser after 250 mile rebild mark oli change
