1991 Toyota pickup rumble from front end
Old 03-29-2015, 09:15 PM
dylansaf's Avatar
Hey guys, my 1991 toyota pickup 4x4 22re has a bit of an issue. When i accelerate from a complete stop up until about 30km, theres a rumbling noise from the front end. After 30km the rumble ceases and, it drives smooth as usual. Im out of ideas, its an ifs with add.
Old 03-29-2015, 09:59 PM
shadowbirdie's Avatar
Is this a european pickup??
Just kidding.. If on a turn, probably a CV, or a failing bearing with a harmonic resonance that dissipates with increase in speed, if so it will get worse the longer you wait
Old 03-30-2015, 09:49 AM
dylansaf's Avatar
It doesnt do it all the time, guess i could try doing the passenger cv, just did the drivers side. Then if that doesnt fix it try the bearings. Thanks for the help
Old 03-30-2015, 10:30 AM
scope103's Avatar
Usually, you can feel a bad bearing just by jacking up the wheel, and turning it by hand. You should feel nothing at all; if you can feel anything I'd suspect the bearing.
To eliminate the half shaft, remove the half shaft, then try turning the wheel. You might have to put the wheel back on (you almost certainly removed it to get to the half shaft) to get enough leverage (the brake could drag slightly).
Old 03-30-2015, 12:11 PM
sometimes one exposes the other
I'm just putting out there, other suggestions posted sound feasible as well.
The loud CV you replaced might have covered the other noise, bearing not totally toast only growl at certain speeds (I speak of an 82 Tercel I had in the early 90's)
And sometimes the new one eats the old one, I did in pairs like brakes
Just my $.02
Old 03-30-2015, 07:34 PM
RJR
RJR's Avatar
You can easily stop the CV shafts from turning just by pulling off the drive plates on the hubs (remove the 6 small bolts and cone washers.). It won't hurt it to drive it around that way (in 2wd) for test purposes as long as you stay out of the mud and dirt. If the noise goes away it's probably the CV shaft. If it continues then you need to look at your bearings.
6th Gear
19
12-10-2019 07:31 AM
Aleeex_u
06-05-2016 06:52 PM
Daneums
06-29-2015 06:38 AM
YotaGreenhorn
06-27-2015 07:00 AM
bprice0077
06-25-2015 07:36 AM
Quick Reply: 1991 Toyota pickup rumble from front end
