1991 pickup. Bj spacers in front; what for rear?
Old 02-26-2016, 12:16 PM
Dustin Egle's Avatar
My tires are rubbing a little (32/11.5/15s on 15x10 wheels) and starting to chunk off so I've decided to throw a lift on ASAP. Also plan on going up to 33/12.5s after the lift. No body lifts. I'm doing a 3" Bj spacer up front, but I'm not sure what to do for the rear? Shackle? (Proper shackle size to get to match the Bj spacer?) Block? Zuk mod springs? Not doing AAL. Don't want the decreased ride quality.
Here's how my truck looks sitting level, not a lot of sag but defiantly lower in the rear just a bit. And I want it to sit pretty level in the rear after I add the BJ spacers.
Here's what I found, if blocks the best option, should I go with this kit since it comes with everything? No idea what the dif drop is for, pry wont use it. Also, why is it 3" in the front and only 2" in the rear? Is there something I'm missing or? Shouldn't it be 3" all around?
http://m.ebay.com/itm/86-95-Toyota-IFS-Pickup-3-Front-2-Rear-Lift-Kit-w-Shocks-Diff-Drop-4WD-PRO-/281820624671?nav=SEARCH
And if Zuk or shackle is better, shoot me a link to what I should get! I just have no idea what length to purchase to match the spacers to get it level. These are the spacers I'd probably use unless you have a better set for a better price. Also shocks as well, 80% DD 20% wheeler.
https://www.google.com/search?q=3+inch+bj+spacers+toyota+pickup&client=ms-android-verizon&sa=X&biw=360&bih=559&tbs=vw:l&tbm=shop&prm d=sivn&srpd=12465064289070993526&prds=num:1,of:1&v ed=0ahUKEwjNl_eFm5bLAhUQ5GMKHdBTAcwQgjYI8wIwAA&ei= 2a3QVo3HJZDIjwPQp4XgDA
Thanks guys!
Old 02-26-2016, 03:33 PM
highonpottery's Avatar
If your 32s are rubbing now, a 33x12.5 will rub even more. My guess is it's your 10" wide wheels that aren't helping and guess you're rubbing on both the pinch weld and the bumper/valence when you turn all the way. My truck sits at 22.5" from center of axle to bottom of fender, with 33x12.5 on 8" wide wheel and I still had to modify those areas to keep from rubbing.
With the questions you've asked I think you should take a read through some of the lift guides for IFS Toyotas, as well as read some of BlazeN8's posts regarding IFS setups where he talks about BJ spacers.
Old 02-26-2016, 03:48 PM
Yeah I know if I added bigger tires now it'd be the worst idea ever. But if I'm going up 3 inches, and I'm barely rubbing bow (only on the lower bumper valance which I even trimmed already as you can see in the picture to match the curve of the bumper) I think I can pull 33 12.5s on a (probably) 17x9 wheel.
Connor G
04-07-2016 06:04 PM
Oleyoter87
01-03-2016 04:36 PM
Monroedoctrine
12-26-2015 07:26 PM
Codyblake
12-18-2015 10:18 PM
MorphiasX
12-02-2015 10:00 AM
Quick Reply: 1991 pickup. Bj spacers in front; what for rear?
