1991 4Runner SR5 - won't turn over... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-15-2008, 03:22 PM   #1 (permalink)
B45
got an old '91 4runner as a bush beater and ran into some trouble getting it started again. A friend of mone tried to boost (battery dead) at night and put the cables on backwards and it hasn't started since. If we hook up the booster cables and spray some gas into the air intake it will run off the gas but then die out. Tried putting on a new fuel pump, still no luck and checked the fuses too. Would the EFI relay fuse under the hood be the issue? Or the sender on the tank? Something else? Just frustrating that I can't get the pump pumping because it does run if you feed it directly in the air intake....
B45 is offline
Old 05-15-2008, 03:25 PM   #2 (permalink)
4Crawler's Avatar
Try the fuel pump test jumper:
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Could be the fuel pump switch in the Air Flow Meter went out:
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
And for sure, check all the fuses under the hood and under the dash.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 05-15-2008, 03:41 PM   #3 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
Check the fusible links in the wires coming from the + terminal of the battery.
Also, may be an ECU fried from the reversed voltage.
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 05-15-2008, 04:01 PM   #4 (permalink)
wardriver's Avatar
Quote:
True but probably wouldn't run off of the ether if it was. Is your fuel pump getting voltage?
__________________
Current Toyota
-95' 4Runner - 3.0/AT - New HG - Yakima Rack - MT's - Hella's - GPS- Sat Radio - Onboard 120V
Former Toyotas - 81' Trekker- 70' FJ40 - 76' FJ40 -72 FJ40 - 85 Hilux (ZERO options)
Staff Mod for nHunting.com a community forum for hunting/fishing/shooting
wardriver is offline
Old 05-15-2008, 04:04 PM   #5 (permalink)
thanks wardriver, I didn't think of that.
check the fuel pump operation by simply inserting the key and turning it on, but not starting it. If you hear the fuel pump run, it's getting voltage. If not, you can connect a voltmeter to the FP terminal inside the diagnostic connector and the - terminal of the battery- you should get voltage for about 2-4 seconds when the key is turned on.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1991 4Runner SR5 question Brown28 86-95 Trucks & 4Runners 12 02-16-2008 07:15 PM
1991 4Runner SR5 V6 Brown28 86-95 Trucks & 4Runners 5 02-13-2008 05:25 AM
TUCKER'S 1991 4Runner SR5 TUCKER 4Runners-2nd gen 0 09-04-2006 12:18 AM
FS: 1991 Toyota 4Runner SR5 V6 FearTheH The Classifieds GraveYard 9 08-16-2006 09:00 PM
2009 InternetBrands, Inc.
