1990 V6 Mass air flow flow part #?
Old 01-15-2008, 03:02 PM
ogclew's Avatar
Hello everyone, im purchasing a mass air flow sensor from a junkyard in El Paso, TX. And wanted to know if a 94 v6 air flow sensor is the same part number? What years work with the toyota V6? I own a 1990 toyota 4x4 SR5 V6, I am barely repairing my truck, a diagnosed one of my problems as MAFS. Any pics bc it looks the same? I dont want to waste money!!!..no refunds..thank you........
Old 01-15-2008, 03:19 PM
MSR
MSR's Avatar
they are the same the toy number should be 22250-65010 but all used parts are not always good. What problem are you trying to fix?
Old 01-16-2008, 01:25 AM
anotherjeff's Avatar
I scrounged Pick-n-Pull for the AFM to fit my '89 4Rnr 3VZE. I found that the AFM from a Corolla 4A-GE (16 Valve) had the same specs (ohms) that the 4Rnr FSM called for. Minus the ducting, they were physically identical. This part has performed flawlessly for about 5 years. Part # 22250-74120.
Pick-n-Pull has a pretty cool "30 day exchange for credit voucher" policy on all parts, but a MAS/AFM part costs about $30 now days, still a good deal if you need one.
Old 01-16-2008, 05:50 AM
mt_goat's Avatar
Your truck doesn't use a mass air flow sensor (MAF) those came along around 1996, it uses a vane or volume air flow meter (VAFM) or (AFM for short).
Old 01-16-2008, 06:10 AM
ogclew's Avatar
really? The part that attaches to where the air filter is located it looks like it? ....are you sure?
Mass Air flow Meter...same thing ?
Old 01-16-2008, 07:33 AM
mt_goat's Avatar
http://personal.utulsa.edu/~nathan-b...92volumeai.pdf
You're just calling it by the wrong name, a MAF is competely different type of air measuring device. A MAF measures air flow by using a hot wire (the more air that flows by the hot wire the cooler the wire gets) and the estimate of air flow is by mass. A VAFM measures air flow by a spring loaded flap door (the more air that flows by the wider the door is pushed open) and the estimate of air flow is made by volume.
Sorry I can't help with the part #, but I thought it might at least help if you called it by the right name, especially if you're dealing with salvage yards.
Old 01-16-2008, 09:38 AM
ogclew's Avatar
Thanks! man ...the diagram helped alot!...i appreciate the info!..
Old 01-16-2008, 09:59 AM
mt_goat's Avatar
You're welcome, I did a search on Car-part.com for a 90 V6 air flow meter and they list everything from 89-95 as being a fit, so that's usually a good indicator the part number didn't change for those years.
http://www.car-part.com/
Gone Fission
01-12-2023 10:34 AM
Pocoyota
09-08-2015 02:41 PM
bighaydn
08-04-2015 07:17 PM
ptb12
07-05-2015 01:49 PM
MTNPATH
02-14-2006 01:08 PM
Quick Reply: 1990 V6 Mass air flow flow part #?
