1990 toyota dlx 3.0 5 speed steering box leak....Repair???
Old 01-04-2015, 02:58 PM
green2man0's Avatar
I have a 90 toyota ext cab 3.0 4x4 that has been loosing power steering fluid. I think I tracked it down to the steering box where the steering wheel shaft meets the box. Can I rebuild the box or install an o-ring? Or is it something where you replace the whole part? The power steering wines a bit when going lock to lock but it's not terrible. I also noticed that after I added fluid to full and started the truck and went lock to lock that the fluid was foamy...I'm assuming the leak lets in a bit of air... is there any vacuum lines that could do this...maybe a bad check valve letting air in?
Old 01-04-2015, 03:03 PM
wyoming9's Avatar
Red face
You are using ATF ??
You only should add fluid to the system while it is running .
You do check the level running maybe your over filling it.
do you have the know how to rebuild the steering box?/
Old 01-04-2015, 04:25 PM
scope103's Avatar
here's the manual (where you should always start):
http://personal.utulsa.edu/~nathan-b...ng/13gearh.pdf
RockAuto sells remans for about $200-250. Considering the special tools and clearance checks called out in the manual, I think I'd go with a reman myself.
That is assuming you have correctly located the leak. Be sure the entire area is sparkling clean before you try to find leaking fluid.
GreenLion
06-07-2021 10:49 AM
Nathan_F
08-19-2015 04:03 PM
ZONAYODA
06-30-2015 05:36 PM
GorgeRunner
06-27-2015 07:01 AM
Eagle564
06-23-2015 11:29 PM
Quick Reply: 1990 toyota dlx 3.0 5 speed steering box leak....Repair???
