1990 SR5 lift help.
Old 06-30-2013, 12:02 PM
Cody1992Davis's Avatar
1990 SR5 lift help.
Hello guys my name is Cody and im just curious in how to lift my 1990 SR5 its a v6 4wd. I have 3 inch lowering blocks for the back that you put under your leaf springs to lower the axle. Im just wondering how to do the front. I have asked everyone and everyone keeps giving me different answers to leveling kits to suspension and shock upgrades to torsion bars. Can some one give me a straight forward answer and what would be the easiest and cheapest way. I dont mind spending a little bit of money but a $100.00 budget would be fantastic. Thanks.
Old 06-30-2013, 12:18 PM
toyota4x4907's Avatar
....You have coils in the rear, those blocks wont work.
for $100 you could get a body lift...maybe....
Old 06-30-2013, 12:57 PM
Toyota~Boy's Avatar
The easiest and most cost effective lift you could get would either be:
1: body lift (1" 2" or 3")
2: BJ Spacers for the front end and coil spacers for the rear.
Here's one http://bit.ly/11SGvLT
Here's another http://bit.ly/12A5wHa
Old 06-30-2013, 01:50 PM
I have leaf springs in the rear not coils. the blocks i have are perfect for the back but theyre 3 inches. all the leveling and spacer kits i see for the front are all 2.5 and 2 inches. Id like for it to look normal. I could always get 2 inch blocks couldnt i and get the 2 inch spacers.
Old 06-30-2013, 02:11 PM
If you have leaves, then it is an '89, not a '90.
Easiest and cheapest is a body lift.
Upper Ball joint spacers are available in 1.5" and 2", IIRC, where if you want more lift, you have to crank the torsion bars.
Usually people put more lift in the rear to counteract sag and because you typically haul heavier loads in the rear than in the front.
Old 06-30-2013, 02:47 PM
Oh well my door says 02/90 therefore i thought it was a 90 i guess i was wrong. Ok so essentially i could put 3 inch blocks under the leafs and crank the torsion bars to give me 2 inches and get some 1 inch spacers?
Flying91
45
04-11-2024 04:39 PM
coffey50
07-28-2015 10:55 AM
Massmayhem247
07-18-2015 05:46 AM
colasurdo
07-16-2015 11:32 AM
ptb12
07-05-2015 01:49 PM
Quick Reply: 1990 SR5 lift help.
