1990 Pickup Power Door Problems
Hey guys I was just wondering if you could give me any tips on how to fix the power door locks and windows on my 1990 toyota pickup 3.0. I replaced the switches on the drivers side thinking that was the problem but that didn't fix anything. I was thinking it may be the a fuse but I couldn't find any fuse with a name related to the power doors? Thanks for reading.
The answers to all questions are found in The Good Book.
http://personal.utulsa.edu/~nathan-b.../8powerdoo.pdf
http://personal.utulsa.edu/~nathan-b.../7powerwin.pdf
http://personal.utulsa.edu/~nathan-b.../2powersou.pdf
You have a 30amp fuse "Power" that controls the motors. Gauge powers the door lock relay, and dome also has something to do with its function.
Replacing a (expensive?) switch on gosh-and-by-golly hope is nearly as useless asking generally for "tips" on how to fix it. This is an electrical problem, there is one tool you cannot do without: a multimeter. Don't have one? No excuse for that! http://www.harborfreight.com/7-funct...ter-69096.html
Since you've already figured out how to remove the master switch, I'd start by checking for 12v to ground on pin 9, and then 12v between 4 and 3 as you actuate the driver's side window switch.
Good luck!
Good luck!
WTB[International]: 93 P/u fuel door lock, roll bar, hitch, chrome rear bumper
Gamble_STi
06-27-2015 07:54 PM
