1990 deluxe 4x4 codes
Old 02-08-2010, 06:16 AM
nitewing's Avatar
Angry 1990 deluxe 4x4 codes
OK I have used a paperclip in the diagnostics box and counted the codes on the check engine light. I cannot figure out what to do to find ou twhat they mean... it blinked 2 times then pause then 4, then long pause then 2 then 5, then long pause the 2 then 6, then long pause then 3 then 1 so if I understand this correctly is this 4 separate codes? 24, 25, 26, 31? or is it a long code with different #'s? can anyone help me to figure out where to read up on this? or at least let me know what the codes mean? THANK YOU!!!
Old 02-08-2010, 06:18 AM
nitewing's Avatar
oh yeah this is a 22R-E, automatic if it matters
Old 02-08-2010, 06:28 AM
BOLTS's Avatar
youve got the code reading right. just search in the fsm for the code meanings,it at the top of each section.
Old 02-08-2010, 06:29 AM
nitewing's Avatar
I no longer have a service manual... lost in the mud? snow? somewhere...
Old 02-08-2010, 06:32 AM
4Crawler's Avatar
http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old 02-08-2010, 06:37 AM
alil2cul4u's Avatar
It would be the 4 codes and they would mean; Code 24 Intake air temperature signal fault, Code 25 Air/fuel ratio LEAN, Code 26 Air/fuel ratio RICH, Code 31 Air flow meter circuit or Vacuum sensor signal fault
Old 02-08-2010, 06:44 AM
nitewing's Avatar
Thank you for your assistance everyone. would the air flow sensor throw codes for air fuel mixture? why would it read both lean and rich? I already figured I wold have to change the air flow sensor. is there a fuel mixture sensor I should look at also?
raptor510
02-17-2017 07:11 AM
gary4runner
09-24-2015 12:53 AM
Gone Fission
07-24-2015 12:49 PM
madxman21
07-09-2015 10:26 AM
ptb12
07-05-2015 01:49 PM
Quick Reply: 1990 deluxe 4x4 codes
