| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
1990 Auto 3vze RPM Fluctuations at idle and others
#2 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
Those compression readings are awfully low. Minimum should be atleast 142psi. Are you sure your readings are correct?
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
#3 (permalink) | |
Quote:
Mine's a '92 V6 Auto 4x4 and every few weeks or so often in 'Drive' my tranny all of a sudden dumps the gear and revs high. Usually if I stop and put it in 'Park' then back to 'Drive' it works fine again, sometimes i gotta shut off the engine, then restart to 'reset' it. Also my speedometer needle fluctuates or sometimes doesn't work at all, but Im thinking this is down to a faulty vehicle speed sensor(VSS) that I keep meaning to replace (doesn't affect the driveability of the truck it seems tho...) Anyone else got any insight on this would be much apprieciated... Thanks |
| Tags |
| 1990, 3vze, drive, fluctuates, idle |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3.0L 3VZE initial idle speed (rpm) on starting | headgasket | 86-95 Trucks & 4Runners | 11 | 01-11-2008 08:54 PM |
| unsteady idle 3vze auto | pepsibluefloat | 86-95 Trucks & 4Runners | 0 | 11-07-2007 01:02 PM |
| A/C and idle rpm | Glina | 86-95 Trucks & 4Runners | 4 | 06-17-2006 01:19 PM |
| 400 RPM Idle drop when in Drive and idle variations | Forerunner | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 10-10-2004 09:03 PM |
| Idle fluctuations on EFI | deathrunner | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 04-28-2004 12:59 PM |
