1990 4Runner No Power
Any misfire or hesitation? If not, i had a similar issue due to the throttle cable. Check out this post https://www.yotatech.com/forums/f116...08/?styleid=41
Codes
How do you read the codes on this thing? Check engine light is on but the standard ODB reader doesn't fit connector. Without going to a Toyota dealer how do I read the codes?
Awesome, I knew I couldn't be the only one with this issue. As far as the Odb port, do you have a ODBII scanner? If so it wont work. That wasnt standard till '96. You will have to use the diagnostic port
Its under the hood behind the battery. I'm doing this from memory, but you turn the car off, jump E1 and T E1 with a paper clip and turn the key . Count the flashes to get the code number. Do a search to find what the codes mean. I think its also in the user manual that came with the truck if you have it.
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
skoti89
07-08-2015 12:05 AM
