1990 4Runner Dash Gauges & Fuses - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 03-30-2010, 10:31 AM   #1
I have taken apart my dash and removed the instrument cluster (some fun getting it out). I replaced all the little bulbs in the back of the instrument panel/cluster and am in the process of reinstalling the cluster. I managed to get the 4 electrical plugs reconnected but am having some difficulty reconnecting the speedometer cable. It is tought because you have to reach in behind the cluster - there isn't much space and you can't see either. I just can't seem to make the connection.
Anyways, the dash gauges all work (other than the speedometer of course). I have not yet put the dash back together. I did drive the vehicle today and at some point all the dash gauges stopped working. Also, my power windows will not work nor my heater fan. Something has gone wrong. Was it a bad idea to drive the vehicle without all the dash connections back together (ie. the dash dimmer switch, the rear defrost button etc). I have found that my fuse for the instrument panel is burned out. What else might I have done - what other fuses etc?
Any advice/comment greatly appreciated
jay4runner is offline   Reply With Quote
Old 03-31-2010, 08:43 PM   #2
hgill's Avatar
There is no harm in driving while having non-critical electrical components unconnected. I think you somehow had a electrical short since everything in the dash is out and the fuses blew.
Make sure there are no shorts or loose electrical wires touching each other or ground. Check all fuses and replace any blown fuse.
It happened to me while working with the electrical stuff in my truck! gotta be careful of electrical shorts
hgill is offline   Reply With Quote
MMA_Alex's 1990 4Runner Build Thread MMA_Alex 86-95 Trucks & 4Runners (Build-Up Section) 22 06-14-2016 06:58 PM
Dash lights and interior lights wont work ashersullivan88yota 86-95 Trucks & 4Runners 12 07-28-2015 07:22 PM
1992 toyota 22re dpridgeon3 86-95 Trucks & 4Runners 21 07-09-2015 02:18 PM
1985 22re a/c install help bryan34w 84-85 Trucks & 4Runners 0 07-06-2015 06:53 PM
How to fix Steering linkage ptb12 84-85 Trucks & 4Runners 1 07-05-2015 02:49 PM
Tags
1990, 4runner, 86, dash, dont, fuse, fuses, gages, gauges, iroc, spedometer, stop, windows, wiper, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
