1990 22re upper radiator hose and intake hose
Old 01-05-2014, 07:21 PM
shafner30's Avatar
hello
just replaced my radiator and both hoses upper and lower hoses on my 1990 22re
so my ?
it seems like the intake hose sits really tight on the upper radiator hose is that ok even with the motor moving up and down on that upper radiator hose..
let me know
thanks
Old 01-05-2014, 08:04 PM
thefishguy77's Avatar
I believe there is some sort of "pad" that rides between them. Or I just imagined that. I will look in the morning.
Old 01-06-2014, 01:01 AM
wyoming9's Avatar
Red face
Why does your engine move up and down? Time for new Engine Mounts??
Is it possible to twist the air intake hose away from the coolant hose.
I know I did that a few times.
You could take your old hose cut it open and cable tie it at the point of rubbing if you are unable to move the air intake hose.
Old 01-06-2014, 04:37 AM
xylicon's Avatar
My upper radiator hose rests against my air intake hose, there is a pad on the upper radiator hose for this reason, checkout the pic.
https://i.imgur.com/gnALDXW.jpg
Old 01-06-2014, 02:14 PM
wyoming9's Avatar
Red face
I have never seen that on any of these engines I have seen.
Quite a few !!
Where did you get that or is the hose original from new??
Old 01-06-2014, 02:25 PM
Gamefreakgc's Avatar
You could just put some foam door insulation between the two. It's adhesive and will take the brunt of the movement and not wear down your hoses. You'd want to put it on both hoses though so the movement occurs on the insulation, not the hose surface.
Old 01-06-2014, 04:40 PM
xylicon's Avatar
I don't remember where I got it, but there looks to be all kinds of stuff like it out there. I just googled "radiator hose sleeve" many options available.
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
Alex Bessinger
08-31-2015 09:17 AM
Poncho0206
07-10-2015 06:21 PM
ptb12
07-05-2015 01:49 PM
Quick Reply: 1990 22re upper radiator hose and intake hose
