1988 toyota truck 3.0 4x4 not starting - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-22-2007, 04:50 PM   #1 (permalink)
well ive tried, the fuel pump is not cutting on so i take the old fuel pump that still works and hook it up to the gas line and run wires to the batt and try to start it up ( nothing) Ive took the timing chain cover off it is still in good condition, the fuel pump is not cutting on( it has a new one and the old one still works, there seems to be corrosion in the computer. I thought it was a gas problem all alone, well it was getting pleny of gas running it straight through a line. Please help, i have mechanic skills but right now im stuck on the issue its giving me. Thankyou.
toyota 1988 is offline
Old 05-22-2007, 07:55 PM   #2 (permalink)
Check for injector pulse. They should have power at all times and the computer will pulse the ground to fire them. You can use a standard test light for this by hooking it to power once you know which are the gound wires or get a "noid" light set cheap from a good parts store that plugs in place of the injector. Power with no ground would be wiring or ecu.
1994runner is offline
Tags
1988, 30, 4x4, 92, automatic, buying, forum, fuel, injector, issue, power, pulse, starting, toyota, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Should I buy this 1988 Toyota 4x4 Truck Glockem 86-95 Trucks & 4Runners 35 02-18-2007 05:39 PM
Should I buy this 1988 Toyota 4x4 Truck? Glockem 86-95 Trucks & 4Runners 0 02-16-2007 03:11 PM
83 4x4 Toyota Truck Starting Problem ckimtang Pre 84 Trucks 3 09-17-2006 02:46 PM
Toyota Landcruiser: 1988 FJ62 vs 1988 GX 4x4 gmmceo Early Land Cruisers 0 05-21-2006 07:56 PM
2009 InternetBrands, Inc.
