1988 Toyota 2WD - Rear brake hose tee stripped, what to replace with and where
Old 03-06-2016, 07:56 PM
zammer's Avatar
Hey all, I was finishing up replacing a pile of stuff on this truck. Front brake hoses went out, in, bled, no problem.
Rear one came out of the compression fitting fine. However, the brake hose runs to a hydraulic tee that is bolted onto the differential. The hose threads directly into this tee, and two hard lines run off to each wheel's drum brakes.
I tried to unthread the hose from the tee - it was pretty clearly stripped and won't come out, just spins and spins. Clearly need to replace the tee....
I tried to find a tee at O'reilly that would work and they are all really shallow - it won't thread all the way in. Plus they don't have the funky bracket to bolt onto the diff.
So the question is: what tee do I need, can I even find a new OEM part for an '88 toyota truck, and if there is some aftermarket option, where to find? Rockauto turned up blank and I don't really know what I'm looking for.
Here are some pics to help explain what I mean
https://imgur.com/a/ieRU2
Attached Thumbnails 1988 Toyota 2WD - Rear brake hose tee stripped, what to replace with and where-2016-03-06-14.33.07.jpg   1988 Toyota 2WD - Rear brake hose tee stripped, what to replace with and where-2016-03-06-19.47.25.jpg
Old 03-07-2016, 12:08 PM
zammer's Avatar
Nevermind, just went to the pick n pull and snagged one off a junker. went in no problem. Now for bleeding :S
Old 03-12-2016, 12:16 AM
wyoming9's Avatar
Red face
Just so people know I really hope you just used the wrong term.
There should never be Compression fittings on brake lines!!
Flared fittings .
Sad fact people do tend to use compression fittings to splice lines together .
Old 03-12-2016, 07:00 AM
zammer's Avatar
I've worked on plenty of motorcycles but never vehicles of the 4 wheeled variety. Almost all bikes use banjo fittings which are definitely simpler... yeah wasn't sure what I was looking at. Apparently the correct term is 'inverted flare tee' and these are 'flared' fittings.
Got it all sewn back up but probably could use some more bleeding yet.
theMonch
01-13-2016 07:15 AM
89Hilux
01-10-2016 09:10 AM
ashersullivan88yota
12-15-2015 05:18 PM
85toyman
12-14-2015 03:34 PM
frogbodman
12-13-2015 01:24 PM
Quick Reply: 1988 Toyota 2WD - Rear brake hose tee stripped, what to replace with and where
