1988 pick up bed rust?
Old 03-16-2010, 11:51 AM
WayneR's Avatar
i know all the 88 and old trucks bed rust. but is their any way to stop the rust before it gets to bad?
Old 03-16-2010, 12:16 PM
turkeykiller365's Avatar
well i think the problem is the seam where the top and bottom of the bed side meet. Maybe u could seal that up it might help. I did when i redid mine but.. idk if it will stop the rust thats already there.
Old 03-16-2010, 01:02 PM
vmax84's Avatar
Sounds stupid, but I simply spray stuff with PB Blaster, seams, etc. Also spray it on stone hits that wipe the paint off until I get around to touching the paint up.
Ghetto, but it helps.
vmax84
Old 03-16-2010, 01:30 PM
works, but WD-40 might not eff up ur paint as much
Old 03-16-2010, 01:31 PM
whooo! 60 posts!!
Old 03-16-2010, 11:01 PM
Western Canuk's Avatar
expensive way - take the box off sandblast/grind the rust off. Primer, undercoat and paint.
Cheap way - unbolt the inside box panels. Sand, undercoat and same underneath and keep it waxed religiously.
My box is long since gone (5 years ago) but yeah it rusts out at the seam where the bed and the box meet and around the gas filler cap.
I've noticed trucks with caps don't do that because moisture doesn't get into the box. If you can stand having a cap on your truck.
I got a mazda b2200 box on mine now so.... problem solved! :0
young buck
18
08-27-2018 02:40 PM
gieselman
03-20-2016 04:34 PM
88sasturbotoy
08-11-2015 01:56 AM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: 1988 pick up bed rust?
