1988 4x2 auto tranny
Old 07-17-2008, 05:52 PM
baliff's Avatar
My great aunt gave me a 88 2wd pu with auth trans and I put a new radiator,hoses,belts,and thermostat but it wont shift into overdrive.Any suggestions on why its not shifting?Thanks
Old 07-20-2008, 04:13 PM
84sr5yoty's Avatar
Is the engine coming up to normal operating temp (usually slightly below the half point of the gauge)?
Otherwise, it's probably a bad solenoid.
Old 07-20-2008, 04:38 PM
rowdy235's Avatar
Overdrive off light on? Press the O/D button and what happens?
Old 07-22-2008, 09:53 AM
fast68's Avatar
man i junked my 88 2wd A43D trans truck last april it always worked great hmm
i did notice thoguh that it wouldnt go into OD until it was at a certain temp
if it was too cold then it stayed out of OD automatically for a while no matter how fast i tried to get it up to
on warm days it always went right into OD at required speed somewhere around 40 miles per hour or so
temp sensor/ECM issue on yours maybe
if the bad solenoid is ruled out
or wiring plug connection corrosion or loose-ness, etc
if these solenoids use any rubber seal or any kind maybe some trans fluid seal conditioner additive may help ?
always is nice to put in higher mileage trannies before its too late and seals go bad due to age and heat
good luck
jasonty
41
12-23-2018 01:00 PM
mskalmus
05-28-2017 07:51 AM
4x4-runner
08-03-2015 07:14 PM
Bucksnuff
07-31-2015 07:09 AM
Quick Reply: 1988 4x2 auto tranny
