1988 4Runner bilstein shocks
I have a basically stock 4Runner. I put 31s on it and a add a leaf. Now I'm trying to do something with the suspension. I don't really mind original ride height, but looking for something with a smoother ride. So would adding the bilstein 5100 series work. Or what do I have to do to put them in?
Also considering long travel when I get the money. If I got TC long travel kit what else would I have to get besides axels and shocks?
I have a basically stock 4Runner. I put 31s on it and a add a leaf. Now I'm trying to do something with the suspension. I don't really mind original ride height, but looking for something with a smoother ride. So would adding the bilstein 5100 series work. Or what do I have to do to put them in? Also considering long travel when I get the money. If I got TC long travel kit what else would I have to get besides axels and shocks?
I put KYB shocks on mine, again, it rides like a truck.
Did you do anything up front or are you raked out from the rear lift? If you cranked your torsion bars to match the rear, get some BJ spacers and relax your torsion bars. That made the most improvement for me.
But in the end, if you are going long travel, then don't waste anymore money on your current set up. You will likely end up needing 4" lift springs in the rear to match, IIRC
I believe the 5100 is only available in a 4"over stock for your application but I could be wrong. From what I've heard a set of new leafs would be good for improving your ride. OME seems to be recommended a lot. I did the rear add a leaf in mine and the ride is a bit stiff.
I have an '88 runner. Those Bilsteins are stiff, not smooth at all. I also have OME medium rear springs, since the Add-A-Leaf pieces crack real easy. Currently there are Bilstein 5100's on the rear. They ride worse than Pro-comp & Rancho but should last longer than 1 year. What happens is they get hot on long drives and fail long before you think they should.
I also put in 23mm front bars to push up the front a little. Now whats scary here is that the Rancho's on the front seem alright, while the rear one's drop like flies.
These trucks have a choppy ride and it tough to tame. Used rancho's but they fail annually due to heat build up.
I am actually thinking of putting those reservoir shocks on to soften the ride while having extra fluid maintain a reasonable temperature. Suzuki lower mounts ans Sky upper mount to get some travel room.
But if I did put those 5100s in the 4Runner what would I have to do to put those or another type of bilsteins in. Like a BJ spacer or what?
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
