1988 2WD pickup 4'' lift
Old 07-22-2008, 10:42 PM
John911's Avatar
Ok just a simple question, im getting a 4'' body lift put on my 2WD Toyota pickup and was wondering after this lift whats the biggest size tires I could probably fit on? I haven't lifted it before so its original height as of right now.
Thanks
Old 07-22-2008, 10:44 PM
Jay351's Avatar
Can't help with tire size, but you might want to consider getting that body lift down to 3". After that the leverage can be a problem on the body bolts.
Old 07-22-2008, 11:50 PM
89silverpu's Avatar
Its your truck and do to it whatever makes you happy but why would you try and make your truck something its not? A 4 inch body lift would be really funky looking not to mention dangerous.
As for the original question my guess would be that you could fit 28" tires
Old 07-23-2008, 12:00 AM
drew303's Avatar
LoL..
Old 07-23-2008, 12:11 AM
scuba's Avatar
hehe...
Old 07-23-2008, 03:01 AM
abecedarian's Avatar
why a body lift at all? a little mix and match and google and you can get at least that much in suspension.
Old 07-23-2008, 04:27 AM
dirtoyboy's Avatar
You should be able to clear at least 38's no problem...
you might need to re-gear your diffs though!
Old 07-23-2008, 05:57 AM
AusTex's Avatar
Body lifts are a cheaper way to lift a truck, not as safe as some other lifts. But seeing as this is a two wheel drive truck, I am thinking you won't be off roading it much and are just looking to put some bigger tires on your truck. I don't think I would try to go any larger than 31 for tires.
If I had a two wheel drive truck I would probably lower the front couple inches and lift the back couple inches. Put some meats in the back and slap a trubo on it and start singing Rice Rice baby dun dun dun dun nun nun forever rice.
mskalmus
05-28-2017 07:51 AM
God's Bounty Hunter
07-08-2015 12:54 PM
MTLroadierunner
07-06-2015 12:17 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 1988 2WD pickup 4'' lift
