1987 toyota pickup truck 4x4 22r no spark
Old 11-21-2015, 08:04 PM
msteinbach147's Avatar
I got a 87 toyota pickup 4x4 22r replace distributor cap rotor plugs wires ignitor and coil and it get sparks when it first turns over then stops getting spark need some help
Old 11-22-2015, 01:34 AM
wyoming9's Avatar
Red face
Coil and igniter are new ??
Some of the Ignition parts can be down right junk.
Wires what brand wires ??
Has the engine ever started ??
You first have spark then it quits ??
Battery voltage to low ??
Old 11-22-2015, 06:34 AM
I got a 87 toyota pickup 22r that was my daily driver. On my way home from work it started to buck and loose power when I would push the clutch it it back fired super loud. So got home replaced the timing chain. Now wont start it has brand new spark plugs and wires got a new distributor cap and rotor new pick up coil new coil and ignitor it gets spark when the truck starts to turn over but then after a few cranks it stops getting spark
Old 11-23-2015, 11:28 AM
jennygirl's Avatar
Did you test the ignitor and coil?
Also sounds like you may have a loose plug wire. You could try carefully squeezing the contacts to make them smaller and grab more. Or if you didn't already, buy Denso stuff for the whole ignition system- the OEM ignition is pretty flawless.
Old 11-23-2015, 12:08 PM
Its brand oem new ignitor and coil when I get time to work on Thursday planing on checking all the ground and wires to see if there are any loose conections
Old 11-23-2015, 12:10 PM
It sparks when you first turn it over then the spark stops and it turns over for a few seconds that's checking with the wire going from the coil to the distributor
Old 11-23-2015, 02:03 PM
jennygirl's Avatar
That is indeed perplexing. Checking grounds and connections sounds like a great plan
Good luck & let us know what you find
Old 11-30-2015, 07:06 AM
Anyone know whats this is called i was looking on another thread and a guy had the same problem changed this out but didnt know what its called he just took it off a different truck he had
Old 12-17-2015, 05:25 PM
morena67's Avatar
how much does the igniter cost you... and where did you buy it...?
Thanks.
Old 12-17-2015, 07:19 PM
Thanks.
I got it from Napa for 350 originally 600 but I got a buddy that works there but that wasn't the problem still trying to figure it out
Old 12-18-2015, 12:36 PM
morena67's Avatar
...Thanks...God speed...!!!
urabus
11-10-2015 07:38 PM
Bowman5115
09-19-2015 03:04 PM
ToyotaMD
09-07-2015 04:44 AM
94yota212
09-01-2015 08:01 AM
Quick Reply: 1987 toyota pickup truck 4x4 22r no spark
