1987 4runner starter is going out....
Old 05-13-2009, 07:50 PM
geminiroq's Avatar
Hey guys,
I have a 1987 4runner and the starter is starting to fail....I am trying to remove it but there seems to be no good way to get to it.
Is there a trick to this or am I just having a brainfart???
Thank you...
Old 05-13-2009, 08:26 PM
abecedarian's Avatar
Did you remove the access panel on the inside of the right front fender well?
Old 05-13-2009, 11:08 PM
wyoming9's Avatar
Talking
I have found the best way is top bolt from the top with a long extension .
Bottom bolt from the bottom if you come in from the back side you can look right up and see the bolt on the bottom. I replace the positive cable on the battery at this time with a thicker new one.
If you have not removed and relocated the fuel filter now is a good time. with the starter out
Old 05-13-2009, 11:16 PM
mrmatson's Avatar
This was my solution
Old 05-14-2009, 11:47 AM
geminiroq's Avatar
Thank you...I will try it like that.
coreyedwards7611
01-16-2016 06:38 PM
ZONAYODA
07-13-2015 07:17 PM
87turboPA
07-12-2015 07:49 AM
shar
07-09-2015 12:38 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: 1987 4runner starter is going out....
