1987 4Runner SR5 4wd won't engage
Old 03-14-2008, 05:29 PM
slamkad's Avatar
Like the title says my 4wd will not engage. The transfer case is working properly and the 4wd light is working. I have tried to switch the vacuum lines at the vsv. I am getting vacuum at the vsv. But switching vacuum lines did nothing. I am at a loss. I have searched everywhere and can not find any info on the add system on the 1st gen 4runners. I am sure I am not the first one with this problem, and if anyone can help you guys can. Thanks in advance for any help that is provided.
Old 03-14-2008, 07:12 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Can you manually engage the actuator with vacuum pump?
Old 03-14-2008, 07:28 PM
hurley842002's Avatar
To be honest I wouldn't even go as far as diagnosing the problem. I would do a manual hub install and call it good.
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
Jnkml
07-06-2015 01:20 PM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 1987 4Runner SR5 4wd won't engage
