1987 22RE won't idle, runs rough below 2000 rpm
Old 11-23-2009, 06:06 PM
Schroby's Avatar
My friend has been plagued with an idle and performance problems on his 22re.
The truck never idles, it is hard starting and must be forced to run above 2000rpm. The problem developed slowly over time, however the fuel injectors, filter, tune up, throttle body, oxygen sensor are fairly fresh and the engine has 80,000 miles on it. He replaced the air flow meter earlier this week. It has been to three mechanics over the last several months but little has changed. Currently, it barely runs so your help is appreciated!
Old 11-23-2009, 06:35 PM
Kiroshu's Avatar
Timing? Intake manifold leaks? Any smoke? Main intake tube leaking? Idle speed wrong? Any codes? TPS? Valves adjusted properly?
Old 11-23-2009, 06:40 PM
rusche's Avatar
Disconnecting your TPS will throw the ECU into limp mode, that way you can eliminate that as a problem
If not I would assume an intake manifold leak, or a timing issue
06-01-2021 01:51 PM
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
Alex Bessinger
06-28-2015 10:05 AM
Quick Reply: 1987 22RE won't idle, runs rough below 2000 rpm
