1987 22re Code 11 help
I'm getting a code 11 which states: "Switch Signal - neutral start switch ON (22re) or IDL point in throttle position sensor is OFF during diagnostic check".
Can anybody tell me what this means? I've just replaced my TPS with a brand new unit, and pretty sure its set correctly. The problem I'm trying to correct is lousy fuel mileage and inconsistant (and high) idle speed.
Thanks!!
Thanks!!
It means you have a malfunctioning or misadjusted TPS. Or the Neutral Start Switch is ON during the diagnostic check.
Ruling out the TPS, it means there's a short the Neutral Start Switch circuit. Unless you intentionally switched it on before checking for codes.
montanatruck
02-26-2017 07:07 AM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
01-16-2016 06:38 PM
