1987 22re 4x4 auto yota
This is my first yota I have ever owned.
It misses while idling and while driving but not bad cause I drive it everyday. I changed all the vaccum lines that I could see and I cleaned the throttle body and the vaccum inlets on the intake. While driving it when I come to a stop and the tranny in R D 2 L when I put the brakes and come to a stop it idles so low that it almost die's and sometimes it die competelly out.
I'M LOST AND DON'T KNOW WHERE TO START AT SO ALL THE SUGGESTIONS I GET WILL BE HELPFUL.
I have replaced the plugs,wires,cap, rotor button. I got the idling set a little high and still does it. I tried adjusting the distributor and It doesn't have much of an affect unless I move it to set the timing low then it will kill the motor if I advance it all the way you can really tell much of an affect
09-04-2015 09:27 AM
