1986 toyota 2wd pickup 22r, wanna SAS this truck! info pls!
i have just purchased a 1986 toyota pickup. it 2wd and has a 22r carb engine. truck currently has 76k original miles and bone stock! my plans right now are to solid axle swap. i have done some searching but also would just like info and opinions from you all. what i would like to accomplish is:
i would like to be able run 33" to 35" tires and dont mind trimming fenders and bed wheel openings. currently the truck is a automatic transmission and thought i may convert to 5 speed manual. im aware i will need a 6 lug toyota rear axle as well as solid front axle that i may have found from a 83 toyota pickup. also they have the rear that im unsure if its best i use that?
what else do i need and what do you all recommend?
i would like to build this to be a decent trail rig as well as get parts needed as cheap as possible. Also if you or if you know anyone selling parts that will help me with this project, please contact me and i would greatly appreciate it.
i do have cash now to start buying parts to begin this build!!!
Funny how the older one gets some ideas one had in their youth look quite labor extensive 40 years later.
If at all possible buy a complete donor vehicle just the time and money spent on numerous trips for little things we all tend to forget make it worth it.
You do have your work cutout for you .
http://home.4x4wire.com/erik/diffs/
Toyota Axle Widths: (top)
(all widths are measured wms-wms, wms=wheel mounting surface)
'79-85 front axle~ 55.5", rear axle~ 55"
'86-95 front IFS~ 59", rear axle~ 58.5"
Tacoma 4x4, '96-up 4runner front IFS~ ???, rear axle- 60"
T100 front IFS~ 65", rear axle~ 66.75"
Tundra front/rear~ ??
'90-97 Landcruiser FJ-80/FZJ-80 front axle~ 63.5"
brake upgrade info:
http://home.4x4wire.com/erik/4runner/brakes/
doing this right for 35" and bigger means relocating the steering box as far forward as you can, plating the frame under the box, tied in with reinforcement that attaches into the crossmember of the front frame area, etc.
if you build it right you can move the front axle forward enough to fit 37" tires without cutting into the cab of the truck.
i would not be making any assumptions about 2wd rear end configurations, for example:
"I have a 5 lug axle with an 8" 3rd from an 85 2wd turbo truck. They are out there."
http://www.pirate4x4.com/forum/toyot...ert-5-lug.html
again here: https://www.yotatech.com/forums/f116...estion-230241/
then i thought about getting a sas kit from trail gear or all pro.
i think that rear end is still the narrow width version?? what most people want is the wider rear end with the stronger turbo/v6 differential, so check what you have on the '86.
brake upgrade info:
brake upgrade info:
the reason for going with the wider rear end in the first place is because people usually cut off the spring mounts, and re-weld 'em back on with the nose of the third member rotated upwards... so you want to have a firm plan in place before you start.
the factory solid front axle housing is pretty weak, it will bend, and some people think that any kind of welding you do on it will warp it... one indicator that it could be bent is when the axle shafts won't pull out of the housing.
if you ever pull a solid front axle apart, keep track of how the shims on the top and bottom of the knuckles are stacked, because that's what centers the knuckle on the ball, and sets the drag when it's turned.
Staff
Your location would help. I know where you could get about all the parts you need if you are local to me. Might be others local to you that could help you out as well.
If I was doing a sas i would get the axles before they are gone.
There is a forum for sas info, so you don't get led in circles about a fairly straightforward project.
Show us some pics when you pull the trigger on this project, good luck and happy wrenching.
alva22re
02-20-2016 04:21 PM
Robinhood150
07-24-2002 11:08 AM
