1986 SR5 Steering Stabilizer/Damper Issue
noob question here. whats the purpose of this part? Mine has been leaking slow and steady for the past 5 years, daily drive, steering still working excellent. What would happen if it was disconnected? Whats the benefit of upgrading to a fancy aftermarket stabilizer??
There are several articles on steering dampers and there are some youtube videos on them also. A blurp I stole from a web site:
The purpose of a steering stabilizer is to tame the action of trucks and SUVs with oversized tires. When you equip your ride with larger tires, you may become a victim of the “shimmy” effect or the “death wobble.” But, a steering stabilizer ends the common vibration problem that larger tires can cause, smoothing out your ride. So, you get improved handling and better ride quality.
I have read that you should not drive without a steering damper. Mine was leaking and was shot (30 years old) . I have not seen any difference in truck since I replaced it, but I know it is doing its job and does not leak any longer
i think that a steering stabilizer is there to absorb the shock of sudden jolts that change the direction that the tire is going, like hitting a pothole or something... it's just a shock absorber.
shooter86314
11
02-01-2016 07:45 AM
RedneckBatmobile
01-26-2016 03:36 PM
Ritzy4Runner
01-25-2016 01:03 PM
mizombie
01-25-2016 07:26 AM
408junglist
01-23-2016 05:30 PM
