1986 4runner shifting problem?
Old 12-22-2009, 03:47 PM
ethanp123's Avatar
ok so i just got back from wheeling and i noticed on my drive back to my house my 4runner was having a difficult time shifting and it was screaching like a belt would. I pulled over and checked the tranny fluid and it was fine. So i set on the side of the road for a while then tried to go down the road and it started to shift fine after that i got home i decided to drive it again it shifted fine for a little bit but then began to act up again but no screaching this time? Anyone have any idea what part of the tranny is messing up? It's an 86' 4runner automatic transmission, also im not sure if this is anything that could of messed up shifting but while wheeling i came close to overheating.
Old 12-22-2009, 03:49 PM
Junkers88's Avatar
Is the tranny cooler in good shape? You might have over heated the tranny, if so you'll need to flush the burned fluid out and refill it. Does the fluid smell or taste burned?
edit: You really should not taste the fluid..... it's something my grandfather taught me years ago. I'd say don't taste it just smell it. (oops)
Old 12-22-2009, 03:53 PM
ethanp123's Avatar
ok thanks!
Old 12-22-2009, 03:57 PM
Junkers88's Avatar
Originally Posted by ethanp123
ok thanks!
Run outside and check the fluid. If it looks blackened or smells burned that will let you know what happened. If it's fine then post back up and I'll do what I can to help.
edit again: I need to stop typing so fast. Burned fluid will smell like rotten eggs, or at least it did in my Ford when I fried the C6.
Old 12-22-2009, 04:11 PM
ethanp123's Avatar
no fluid is fine it does the first couple of shifts fine but you get up to 40-50 mph and it's not shifting just running really high rpms like 4,000-5,000
Old 12-22-2009, 04:38 PM
Junkers88's Avatar
no fluid is fine it does the first couple of shifts fine but you get up to 40-50 miles per hour and it's not shifting just running really high rpms like 4,000-5,000
That sounds like a torque converter issue.
vasinvictor
01-20-2016 12:39 PM
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 1986 4runner shifting problem?
